Displays information about the OSPF area.
| detail | Specifies to display the information in detailed format. |
| area-identifier | Specifies an OSPF area. |
N/A.
None.
The following is sample output from this command:
# show ospf area AREA ID Type Summ Def Num Num SPF Num LSA Metric ABR ASBR Runs LSAs Checksum 0.0.0.0 NORM ---- ------ 0 0 0 0 0x0
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
